If you could fine some good H beams you could build one.
Thanks. We have been really enjoying the new presses. I will take a short video of it bending ¼ steel. It does not even break a sweet.
I sold my 40 ton press and applied that money toward these. that brought these down to $825.
https://ecorenovator.org/forum/showthread.php?t=7341
I just ordered quick connects for one of the pumps so I can connect up the new hydraulic punch. That thing is heavy.
Still debating on ordering a 100 ton punch from china. I will see how the holes look with this one before I decide to spend that much money. It may be possible to punch hole a little under size and ream it.
I am going to try a Drill-Use Annular Cutter adapter. It just came in.
My cheap drill press goes down to 300 rpm so it may be good for this job.
Yes this is going into my $10 drill press.
https://ecorenovator.org/forum/showthread.php?t=7196
