Old 10-18-14, 04:52 PM   #21
vwhead77
Cool Different Design - same goal
Ok - second experiment - external coil / discharge from HP - (it's actually a lot more wraps than the internal coil) I managed to wrap 30' of 1/4" copper around a 2" copper pipe. I'm going to insert it into a 4" PVC jacket and fill it with 'fire rated' foam insulation. I'm thinking that a smaller water tube diameter with flow metered by ball valves, will actually give me a decent HX rate. I will have to transition from 2" to 3/4" and use my installed unions (previous pics) to interchange all these gizmos I'm making - (hey I'm semi-retired so I get to play with stuff).
Update : 10/30/14 - INstalled the hp water heater with the coil wrapped around the outside of a 2" pipe/insulated/ and throttled with BVs. Using R209, I have managed a 20 degree differential across the jacket at 4.5 amps. My electric 208V only gets 10 degrees at 12 /14 amps. Definitely gaining ground - my only issue now is the best placement for the outlet side. so far so good
vwhead77 is offline   Reply With Quote
The Following User Says Thank You to vwhead77 For This Useful Post:
buffalobillpatrick (10-23-14)
