Old 02-08-21, 08:39 AM   #14
pinballlooking
pinballlooking's Avatar
Bad news
It now it has a pin hole dripping water out the bottom. Time to look for a new tank.
I am bummed about it.
Here is it running and all put together.
I took the large plug at the bottom out. 18 pipe wrench and a 3 cheater bar.
Then me jumping on it more than once to get it started.
There is a rust in the bottom I may pressure wash it and determine if it one spot or it is just shot.
It had a 2-3 gallons of water in it when I bought it home. I do not know home many years it had that in it. Maybe that water was in it for years. It is 45 years old.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
