The most it will be lifting is ½” plate about 653 pounds.
My tractor just lifted 3/8” plate about 500 pounds.
I checked my hydraulic pressure and mine was low on my tractor I bumped it up and it was able the lift the 3/8 plate.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
