Michael,
My panels can be adjusted between 7 to 30 degrees. I need wrenches and some help to change angle. The offset of sun to panel angle is small, going back and forth between those two angles. So basically I have a summer and winter tilt only. I'm at a 31 degree latitude.
Vern To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
