I would get a copy of the letter and email it or fax it to power company. Call the power company and see if they will move it up the meter install.
Once my inspector office called the power company I called the power company right away that helped get my meter installed the next day.
It can’t hurt to try.
It is fine to post in my solar thread. We all post our solar results there each month. It is a great place to show solar can work for the DIY installer.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
