I disagree completely. Container homes can be made very eco-friendly. It all depends on the upfront planning and design work. As with any home, good plans are essential to sound construction and ensure a lot less trial and error later.
As far as material goes, much of the superstructure can be made from recycled containers. There is no shortage of containers, there are literally millions Of used containers being traded every year. Finding a suitable used container is merely a matter of inspection. In general, even an aged shipping container is at least as durable as a normal wood and plastic stick built home.
As far as finishing and aesthetics go, container homes are favored by people who like an industrial or modern style over a more traditional look. With both types of homes, insulation, plumbing, heating, and ventilation must be added to the structure. Different sites and climates will require different solutions. Within the same locality, these needs will be very similar. Again, more planning invested prior to the build pays off big time.
As far as time to build goes, a container home has a distinct advantage or few. Being a previously manufactured product, the container does not need to be built from the ground up. An average stick home takes around six months to build, and dozens of workers of many disciplines. A container home can be built by half a dozen people in a month easy. With both types of construction, custom work takes longer, but with most container homes, the skin is the exterior finish. With a stick built home, once the sheathing is on, there are still a few layers of exterior to finish.
As far as money goes, lots of elements between the two types of construction are nearly the same. Insulation, heating and cooling, interior fixtures, planning, windows, doors, etc. are comparable in price. Finding items to reuse or recycle can save oodles of costs. The superstructure is not that far apart between methods, either. A major difference is finding financing and zoning or building approvals. Due to the "abnormal" construction, the container home has an enormous disadvantage.
Designing eco-friendly elements into the home can be done on both types of structures. Again, costs are comparable. When all is said and done, what you put into the project is what you get from it. With a stick built home, you may or may not add much resale value by adding these options. Same thing with a container. As long as you are happy with the end product, and are proud enough to live in it, why should it matter?
