Old 12-01-15, 03:02 PM   #24
oil pan 4
Land owner
Now I can tie the Solar assist: Vehicle roof top solar panels - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com to the home made solar inverter generator.
My UPS plug to MC4 adaptor turns all the roof top solar panels into 1 pair of solar panel side MC4 connectors.
I know its looks short but I have a pair of MC4 extension cables that are 12 gauge and 10 feet long, if I need anything longer I have a bag full of MC4 connectors and two 500 foot spools of 10ga wire.
You may have noticed in another picture I installed a gray Anderson connector on the battery. I use those for regulated battery power only, nothing higher than 14.8 volts.
MC4 and white UPS plugs are for raw solar panels power, up to 22 volts.
You maybe wondering why I have 2 plugs for raw solar panel out put. I noticed the MC4 connectors don't disconnect that quickly. They lock together so if they get pulled on they don't separate. I needed something I could just pull on to separate for my external vehicle applications.
