Should also have mentioned it's the angle of the collector itself I'm concerned about. Optimum is generally latitude plus 10 or 15 degrees to bias performance to the lower winter sun angle but in this case I'd be closer to 20 degrees above flat. If it would work summer DHW preheat would be taken care of.
