made a tube in tube water to R22 exchanger
36mm inside diameter PVC plastic pipe carries water
Inside the PVC pipe have 18 mm diameter coper pipe with R22 inside.
25 meters length = 60,000 BTU/hr ( 17 kW)
for your 18,000 btu, 10 meters of tube in tube water to R22 is good for the evaporator.
my use is heat pump only, water to air, the tube in tube described may not work as well as condenser.
