I saw where super clean would help clean up the block and the head. We tested it on the head it was 30 degrees outside so we did not spend that much time on it yet. But it worked well. I look forward to using it on the block and the head again.
Before and after (I just sprayed it on let it sit pressured washed it off)
$9 at Walmart
Some or my parts
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
