Old 02-07-10, 10:54 AM   #5
Ryland
If you can, glue/seal the edges of the foam to the wall as well, also around things like that window, you should check for drafts, our basement window has a layer of shrink fit window film over it, you can also put a storm window on the outside, might as well do both if you can.
