Old 06-30-18, 01:51 PM   #12
NiHaoMike
NiHaoMike's Avatar
It's pretty easy to find 120mm fans in the 100 CFM range. (Delta is one common brand.) A few are even into the 200 CFM range. How much area do you have to work with? The little 5000 BTU unit I hacked long ago had enough area to fit 6 120mm fans, but I only put 2 because that's enough.
