Try this V0.00001
Made a couple of corrections and added input D8 to simulate flow sensors reading 10L/m for testing.
Run code on simulator and seems OKish except the thermistor code, can't get additional lib's to work in the simulator for some reason.
Code:
#include <Thermistor.h>
double evaporator, condensor; //Variables for temperatures from thermistors
float HpLPM; //Flow rate from flow meter in L/m
float HpLPM1; //Flow rate from flow meter in L/m
int minLPM = 3; //Minimum flowrate to run HP
int minEv = 2; //Minimum evaporator temp
int maxCon = 65; //Maximum condensor temp
byte runHP = false;
byte runCompressor = false;
byte runOutPump = false; // pump to circulate water to house/tank
byte runInPump = false; //fan in case of ASHP
const int demandPin = 4; // input connected to external thermostat to request heat
byte demand = false; // variable for reading if heat required from thermostat
unsigned long compLR; // Time compressor was last run
unsigned long hpStarted; // Time HP cycle started
unsigned long hpStopped; // Time HP cycle stopped
volatile int NbTopsFan; //measuring the rising edges of the signal
volatile int NbTopsFan1; //measuring the rising edges of the signal
int hallsensor = 2; //The pin location of the sensor
int hallsensor1 = 3; //The pin location of the sensor
byte led = 13;
byte ledState = false;
byte comp = 5;
byte inPump = 6;
byte outPump = 7;
unsigned long prevMillis = 0; //used for led blinking
Thermistor temp(0);
Thermistor temp1(1);
byte simulateFlow = false;
// ********************Temperature measurement starts here**************
void readTemps() { //read all temperatures from thermistors
evaporator = temp.getTemp();
condensor = temp1.getTemp();
//evaporator = 20;
//condensor = 20;
// ********************Temperature measurement ends here**************
// ********************Flow meter reading starts here**************
void hpFlow () //This is the function that the interupt calls
NbTopsFan++; //This function measures the rising and falling edge of the hall effect sensors signal
void hpFlow1 () //This is the function that the interupt calls
NbTopsFan1++; //This function measures the rising and falling edge of the hall effect sensors signal
void readFlows()
NbTopsFan = 0; //Set NbTops to 0 ready for calculations
NbTopsFan1 = 0; //Set NbTops to 0 ready for calculations
interrupts(); //Enables interrupts
delay (1000); //Wait 1 second
noInterrupts(); //Disable interrupts
HpLPM = (NbTopsFan / 2.75);
HpLPM1 = (NbTopsFan1 / 2.75);
simulateFlow = digitalRead(8);
if (simulateFlow == true) {
HpLPM = 10;
HpLPM1 = 10;
// ********************Flow meter reading ends here**************
void setup() {
pinMode(hallsensor, INPUT); //initializes digital pin 2 as an input
pinMode(hallsensor1, INPUT); //initializes digital pin 3 as an input
attachInterrupt(0, hpFlow, RISING); //and the interrupt is attached (1 for Leonardo 0 for mega/uno)
attachInterrupt(1, hpFlow1, RISING); //and the interrupt is attached (0 for Leonardo 1 for mega/uno)
pinMode(led, OUTPUT);
pinMode(comp, OUTPUT);
pinMode(inPump, OUTPUT);
pinMode(outPump, OUTPUT);
pinMode(demandPin, INPUT);
compLR = millis();
pinMode(8, INPUT); //disable flow sensors for testing, high simulates 10L/m
void loop() {
readTemps();
readFlows();
demand = digitalRead(demandPin);
unsigned long tm = millis();
if ((demand == true) && (compLR <= (tm - 120000))) {
if (runHP == false) hpStarted = tm;
runHP = true;
else {
if (runHP == true) hpStopped = tm;
runHP = false;
//*****HP startup cycle********
if (runHP == true) runInPump = true;
if ((runHP == true) && (hpStarted <= (tm - 30000) && (HpLPM > minLPM))) runCompressor = true; //Delay compressor start 30s after starting in pump
if ((runHP == true) && (hpStarted <= (tm - 60000))) {
runOutPump = true; //Delay out pump start 60s after starting in pump
ledState = true; ///turn on pin 13 led after startup of HP
//*****HP shutdown cycle********
if (runHP == false) runCompressor = false;
if ((runHP == false) && (hpStopped <= (tm - 120000))) runInPump = false;
if ((runHP == false) && (hpStopped <= (tm - 300000))) {
if (runOutPump == true && ledState == true) compLR = tm;
runOutPump = false;
ledState = false; ///turn off pin 13 led after shutdown of HP
//***Check flow rates above min***
if ((runOutPump == true) && HpLPM < minLPM || HpLPM1 < minLPM) {
if (runHP == true) {
hpStopped = tm;
compLR = (tm + 600000); //prevent cycle restart for 10m
runHP = false;
//***Check evaporator/condensor above/below limits*** not intended for defrost purposes, halts system for 30m
if (evaporator < minEv || condensor > maxCon) {
compLR = (tm + 1800000); //prevent cycle restart for 30m
runHP = false;
digitalWrite(led, ledState);
digitalWrite(comp, runCompressor);
digitalWrite(inPump, runInPump);
digitalWrite(outPump, runOutPump);
