I've used it and it seems like good stuff.
When applying it to a flare, I recommend putting some on both the inside and outside of the flare.
Anywhere two metal parts are going to rub each other.
I think the lube effect will allow the flare to shape itself
around the flare cone, without binding or galling on the brass.
