I'll have a look at that. Keep in mind I'm not doing an EV build. I'm using the modules for SESS (solar energy storage system)
A few folks have looked at the heater. It was designed to operate at very high voltage. So once you break down your pack its not that useful.
Those who have tried to keep the fluid based heating cooling have had very poor luck. Leaks abound.
Air based heating and cooling have no leaks. And have proved quite simple to use. Just do nothing. Smile. The original ESS built by Sandia in 2012 opted for air based heating and cooling. When you don't have the heavy demands of vehicle use you don't need the robust temp management.
Great link tho. Thx.
Current projects
Chevy Volt battery pack conversion
Blog that is down right now but will return To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Business where I sell solar stuff
[url]https://www.bobolinksolar.com
