Rain water collection
This could go in a few different forums, but I choose here because I plan on using the water for gardening purposes. I'll probably wait until next year, but I would like some ideas on how to build a rain water collection system. The garden area is right behind my garage, so I plan on collecting the water off of it.
The initial plans are to use those blue plastic barrels as holding tanks. The gutters (which need to be put on yet) would route the water to these barrels. I'd get a bulkhead fitting for the tanks and connect them together and to a hose. I was hoping I could get away with a gravity fed delivery system so I didn't need a pump. I think this will work.
Anyone have a system already setup that could provide some info?
