Originally Posted by MetroMPG
I'm looking into it for my garage roof. It's not quite optimally oriented: ~30 degree slope, facing ~235 degrees (a bit west of southwest, which is 225 deg).
At the latitude of Toronto (43 degrees) the optimum angle for highest year round production is from 29 to 34 degrees. This would be he angle you would want for a MicroFIT system as it will give you the best return on your money. You will make a bit less in winter but it will be made up in summer.
