I'm not sure. I just keep foam, guns and caulk inside when not in use. I hope the top side of my sheet rock is above freezing :/. Usually the problem is that things are too warm up there. That's why air sealing is needed. I just saw a house with no insulation in the attic at all see a blower door reduction of 4,600 CFM 50 to 1,100 CFM 50 with common air sealing techniques. I have seen large expanses of two part foam fail. That is corrected by spraying water on the surface first.
My project:
