BBP,
Ormston has just offered new code, so I should get your comment here...
Just looking at Ormston's code, it does include flow measurement, which is valuable.
...and Ko_deZ's code seemed locked up...
What do you think?
BTW,
I think that since we are going without a Wiki or anything,
if changes are made to some version of code, we should zip the new sketch and attach to any comment.
I also think that we should consider Ko_deZ's code and Ormston's current code to each be Rev00, and if we make mods we should cite the base code-source and increment the sketch we use as a basis for our mod.
For instance, a sketch with a mod to Ormston's code might begin with:
Code:
//Ormston Rev01
#include <Thermistor.h>
double evaporator, condensor; //Variables for temperatures from thermistors
float HpLPM; //Flow rate from flow meter in L/m
float HpLPM1; //Flow rate from flow meter in L/m
int minLPM = 3; //Minimum flowrate to run HP
int minEv = 2;
OR
Code:
//Ko_dez Rev12
/* First some legal mumbo jumbo:
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
NOTE: Bold added only for clarity of this illustration
ETC.
Does this seem agreeable to all?
Best,
