Originally Posted by berniebenz
No, very easy removal. The sense tube is an intergal part of the thermostat. It has a glan nut on it that seals in the header that also seals the evaporator tubing into the tank.
So, when you removed it, you took out the sense tube and replaced it with a bolt?
