You are very much like me when I was deciding I have the space or can make more space if needed.
With using good equipment and you are. You should go with cheapest cost per watt installed. Solar is great in all but fast payback trumps everything!
There is no way I would wait for 72 cell panels. Enphase had a product for them in the past and had many issues with that product.
The M215 has proven itself in the field as dependable any new microverter will not have time to prove itself before you will install.
If you find a great deal jump on it keep in mind shipping is very expensive for the big items and combine them as much as you can.
I found that the smaller items is where the make up their margins. I bought most on the smaller items off eBay. They smaller items just push shipping even know it should not.
I got Enphase wire clips off ebay grounding clamps… it all helps faster payback time. I went to the guys I was ordering the big stuff from and said I can get the Envoy off ebay can you match and they did.
Now that you decided to get solar every day you wait is costing you money.
Don’t forget to look at the cost of waiting in your calculations.
Really now you know how much you will save each month so there is a cost to waiting and that cost is more than the small amount you will save by waiting.
I made over $400 worth of power in the last two months you will make more than that. Just missing this summer will be expensive for you.
