Originally Posted by oil pan 4
It's an off brand senville with a Toshiba compressor off eBay straight out of Compton for $990.
Also picked up a cheap manifold gauge and 2 stage vac pump. All I had before was my jerry rigged setup with a air powered vac pump and some lines, an automotive vacuum gauge and a 200 psi well water pump gauge.
For pulling out a large volume of air the air powered pump still wins but only draws about 1 inch of mercury away from an absolute vacuum.
I have that unit in the 12,000 btu flavor for a 550 sq ft area. It can freeze you out if you let it. Not a bad selection. For my downstairs I am going with 9,000 btu at 27 SEER.
