Old 06-24-16, 03:12 PM   #1900
Originally Posted by Spiv View Post
Hello AC_Hacker,
Any help to get on the right track deeply appreciated!
Keep smiling
Stefano
Sure, glad to help if I can.
To start things off, it is wise to begin your design with considerations regarding conservation of heat (and cool) as your primary concern. That way, whatever heating or cooling system you choose will be the smallest and least expensive to operate.
Too often people begin with the heating system ideas and work backward from there. The only thing true about this approach is that it is backward.
If your heating and cooling needs are low enough, then alternative heating and cooling methods become feasible.
Don't fall in love with radiant floor, or even solar. Your properly designed house may not need it.
I haven't tracked your previous posts, but if you can give a general outline where you are headed (the drawings you included are great), we can get this conversation rolling.
Where will your house be located? ZIP CODE?
Welcome,
jeff5may (06-24-16)
