Oil Pan 4,
After awhile when you see how efficient the mini splits are, you may find yourself doing as I do, letting them run 24/7 in auto mode and switch back to heat or cool mode for the bedroom for the night, though with the Senville Aura unit it will try to maintain plus or minus 2 degrees from set point in auto mode so if that works for your area, all the better than fiddling with it.
