Our winters are quite a bit warmer here. I advise most folks with propane to go with heat pump hybrid. Primary heat from heat pump and propane for auxillary back up. Operating cost of a good 14 seer heat pump is cheaper than propane, especially if you refill in the heating season. Plus it reduces most of your propane use.
