AC
It is indeed air source. First attempt at assembly failed. I put a twist in the tubes so when I went to turn the bung (adaptor) in the tank the tubes would straighten out again. Not so lucky. Tubes kinked!! dam!! Working on a better simpler solution. A photo will explain best.
Randen
