I'd use the power chisel to break out one brick. Then, if a pry bar won't crack the rest of the floor and rim wall you can move a little dirt from behind or under the floor/wall to make a void to help crack the floor/wall. Just hope there isn't rebar or mesh in the 'crete. You probably don't have as much overhead clearance as you would like for the sledge hammer, but it should do the trick.
If you have a teen-aged son challenge his manliness..."bet I can bust more out than you can."
