Old 11-29-14, 04:54 AM   #16
quantumenergy1
Guest
Posts: n/a
I had also applied it but it did not gives that good result that is expected.then i tried another technique known as nansulate insulation coating techniques.this technique based on nanotechnology.its a insulation that prevent the outer heat to transfer to inner side and keep the inside cool.
