I like the ynot7201's idea, thinking about implementing it.
I'm thinking about putting solid aluminum pipe into a duct, rectangular or flattened 6" round one. May be adding some fins between inner and outer pipes for more efficient heat exchange.
Outer duct will draw air from outside.
I wander if anybody did this.
I'm concerned about a moisture.
In my case I have to run vent pipe 6 feet up. So if heat exchanger is efficient enough and some of the moisture condenses, it will collect in the duct.
Any experience there?
