Old 03-03-21, 10:10 PM   #18
pinballlooking
pinballlooking's Avatar
My motor mount came in. It fits the motor but the platform is not big enough. I will need to extend it to the pully side and back a little.
I think I will cut some ¼” plate to put under it.
Here is a good pully calculator.
https://www.blocklayer.com/pulley-belteng.aspx
My large pulley is 16” my small is 8” 5/16” motor is 1740 RPM that puts the pump right at 904 RPM.
I bought the single-phase motor with the same size shaft so I could use the original motor pully.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
