DIY 1000 watt wind turbine
Here is a cool DIY on how to build a wind turbine. Its not incredibly through, but its decent. It hows how to make the hub/bearing/generator, but doesn't really go into how to make the blades all that much. It has links (quite a few) to sites that have more info though.
