If the water in the tank wasn't going anywhere, the naysayers here might have a valid argument. Unfortunately, the water passes through the tank in a finite amount of time. The scale insulates the heat source from the water, so both the raw btu throughput and the recovery time are directly affected by the layer of scale. The thicker the scale layer, the worse the performance. They don't call it resistance for no reason.
