I've discovered that if I turn my TV off that the gateway stops receiving signals. Why I have no idea...
I guess I'll try some other plugs and see what I get...
<edit> Luckily I have no issue drilling holes through my basement office walls. The Gateway is now plugged into the same circuit as the washing machine and works no matter what the TV is doing. I'll have to check when the washing machine runs if it's still working...
</edit>
Reason: solution found
