Old 12-20-19, 03:06 PM   #6
wlbryce
NiHaoMike that is a great project. The high voltage of the Tesla inverter always scared me off because of the expensive cost of the HV components (and HIGH VOLTAGE DC). HV solar components are available, but its limited to more commercial type gear.
Low voltage systems are just easer to build. But, if you can manage to build it would usher in a great use of the Tesla Inverter.
On a side note I use a Schnieder XW 6848 to do exactly what you are wanting to do. My Electrical Coop makes interconnection way to expensive to do. So I have the XW set to Grid Interactive Net-Zero and set the SELL amps to Zero. It will then use my battery power, and excess solar to power all my loads until I hit a DOD that I set. The inverter will pass through extra energy if I go over the inverters rated output. I know that both the XW and SW can do this.
Logan
instagram .com/wlbryce
wlbryce is offline   Reply With Quote
