Originally Posted by Mikesolar
Gotta chime in here. If you have any current or future reason to go off grid, stay away from Microinverters. Also, if you have no shade issues, you bucks are better spent on a good string inverter with battery capability like the Outback.
A direct PV driven DC well pump is way better than the current AC one.
I am pretty sure Mike has lots of solar experience.
Mike what is a ballpark price for someone using 1900 kwh to go off grid?
Keep in mind I have very limited solar experience. You may not have the same requirements as I did. I was doing a self-install that needed to have a fast payback time. Also since I was doing a DYI I needed to be able to maintain the system myself. I required module level visibility I knew no other way to hold them to the new module warranty without that data. I also did not want one or two components to take down my whole array while I waited a month or two for the warranty work to be done. When I compared string inverters I added extra warranty so it was a better comparison.
I read lots and lots but that is not a substitute for real world experience with lots of solar installs.
