Old 02-04-18, 02:41 PM   #9
ThMihov
Hi again
Unfortunately,in the past few days i had no free time to update my project,except that today before i went to the other garage to repair my car,i turned the heatpump,to see if it can heat up the garage,since today was warmer then the last time-it was 7C at 77% humidity.The result-2 hours after i turned it up without waiting the water to heat up before i turn on the indoor unit fan,and turn it when the AC was turned on,the room was 25C.The starting temperature was 14C.So it works,it only needs some patience for the initial room heat up .If there is some free time this week after work,i'll finish the electronics for the control of the AC and for logging and I'll finaly post them here
ThMihov is offline   Reply With Quote
