Since I belive only half to 1/3 of oil is turned into gasoline so even if everyone switched to electric vehicles that doesn't make the pipe line obsolete. The oil companies should be worried, gasoline production is a huge source of revenue.
That gasoline and gas oil will have to be hydroformed into heavier products. So there is no chance they will be stuck with tons of gasoline no one is buying.
Still have to make jet fuel for air craft, diesel for heavy movers to include farm implements and ocean going vessels, petrol chemicals for pretty much everything, lube oil for anything with moving parts, asphalt for roads and roofing.
You do realize the pipe line creates less job opportunities internal combustion engines since they were moving the oil by rail. No pipe line doesn't keep the oil in the ground. Due to a lack of generating capacity.
No pipe line just means the oil gets moved by less safe less efficient means through populated areas.
The 30 amp plugs are perfect for home charging stations.
You could wire a home for a super charger, but it might just be easier to run a second service drop for it and that if it doesn't over load the neighborhood overhead lines and transformers.
The only place that might not be able handle the large influx of vehicle charging is California since some summers they can't seem to keep the power on because of all the air conditioning going on.
