Great Numbers! It is working good.
If my install has those number I will be supper happy.
Do you see the loop temp change much from the Oct to end of winter?
How much power does it use when the second stage kicks in?
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
