--My Climate Master does not have the type of restriction that you speak of. No electric heat on it either. The unit will generate a fault and shut off the compressor if the loop temp drops below 34F (if I remember the temp correctly). The manual says that a trace on the circuit board can be cut to eliminate this temperature cutoff if the loop is designed to run at lower temps. So far I haven't had a need to do this.
--I had to run to the Jersey shore to pickup this Ebay win, but it was a brand new unit for $600. A contractor had an extra unit from a hotel job. A small hint is to use water source heat pump as the search term to bring up more of these types of deals.
