Old 09-24-13, 07:08 PM   #31
Mikesolar
Mikesolar's Avatar
Originally Posted by randen View Post
Fellow Eco-renovators
Look at the crate that showed up. Three nice sized new Brazed plate heat exchangers. Two will be to rebuild the 5 Ton heat-pump. I had found the tube and shell HX that I built was marginal in capacity so purchased some more appropriate BPHX. The HX were built to order with the proper brazed connections on the refrigerant side. and pipe thread on the loop side.
The third BPHX is going to be used for the house solar hot water. I'll post the activities on this install in another post
Looking forward To having the 3ph control for the compressor. And hopefully some really good COP.
Randen
Do the HX have distributors on the vapour outlets? Quite important. Also, once you have checked them out for quality, please let us know who to order from. Alpha Laval is a bit pricy
