Yes you can service the A/C clutch on older GM cars . Do not know about your Saturn ?
Check online at the local parts store web site to see if you find clutch parts .
Then look for you tube videos to show you how to do it .
The older GM clutches , if the clutch gap is too wide , it will not work properly . You may need to check the resistance of the electromagnet ? And if it is creating any magnetism when powered with 12 VDC .
God bless
Wyr
