You will cause a problem with 1" piping all over and such a small necessary flow rate. The pump will not run in its "safe" part of the pump curve. Piping needs to be sized properly, both for proper flow (quantity) and resistance to flow (head). The upshot is that the pump may not last a long time if it is not sized for the conditions.
