Originally Posted by Vern2
TED Home Pro is sending out another MTU to add solar. I'll be able to have my kWh numbers all on one screen. With the Spyder, break out, cloth dryer, hot water, shop (2 ton heat pump, welders, Air compressor, plasma, spot welder) as one number, Volt charge and house 5 ton heat pump.
Have you thought of using pvoutput.org. I have my TED5000 set up going to post data there and gives great graphs, compares to pvwatts predictions, compares to other systems output as well.
