Thread
Affixing insulation board without thermal bridges?
10-24-16, 06:08 PM
6
If you are using the foil-faced polyiso board, it makes for a pretty good vapor barrier. If you tape your seams on the inside, that counts as a vapor barrier. Make sure not to inadvertently build a vapor barrier sandwich.
stevehull
(10-24-16)
View Public Profile
Send a private message to jeff5may
Find More Posts by jeff5may
