Old 04-25-12, 08:50 AM   #14
S-F
You Ain't Me
S-F's Avatar
Just a heads up. Tremco is about the only thing I have found to reliably adhere to poly
Dealing with these kinds of crawl spaces is always rough and I have yet to find an approach I like. And I've tried them all.
My project:
The Following User Says Thank You to S-F For This Useful Post:
gasstingy (04-25-12)
