Here are a few more pics to show my progress. I almost got the solar panel rack up today. I was just 12 3/8" galvanized bolts short of finishing the rack mounting system.
First off, I had some visitors drop by
that's a flock of turkeys ... sawing, hammering, doesn't bother them.
Got the door installed, I believe if you go look at S-Fs post on his basement reno you'll find my moaning about my door install. Note to self: ignore written instructions.
and, ta da, the hinges are on for the panel rack
I'm using dock hinges. This way I should be able to set the panels flat or parallel to the ground during strong wind storms; at 30 degrees for the summer; 45 degrees for fall and spring; and 60 degrees* for the winter.
(A neighbor has a professional system and I want to check his winter angle, the guy who did his system (Isolara?) is one smart guy, so ...)
Maybe next year I'll dream up a way to put in some kind of elementary sun tracking.
