A few pointers..
If you get the code up and running then:
If you open Windows Explorer and go to Network you should see your heatpump listed there, double click to open the web interface..
If you open the web interface and go to <your IP>/debug.html you'll see the debug output from all the routines.
With no sensors connected the sensors return -6c, this will force a defrost cycle to occur at regular intervals..
