I have a windblue 540 that is very low on amps so i was wondering if i replace the 540 stator with the 512 stator if i would get a big improvement on the amount of amps it produces? Here is the link for the 512 stator:
Permanent Magnet Alternator Wind Blue Motor Wind
I am planning to design a gearing system for it using bicycle parts like chain/sprockets etc. Any idea as to what size/ratio I should use. Because the cutting speed is over 650 rpm much higher than the 540 that i have now using.
I have a 5 blade design, windynation 28" hyperspin blades. Should i change these or use 3 instead of the 5?
I am anxiously waiting on your comments/ideas.
