It is the mod SENA-24HF-Z.
When it gets here I will start a post on it.
I'm going to put it on a concrete pad as I did for my other split.
Last year we were using a very inefficient 10,000btu portable air conditioning unit. The kind that rejects heat through a dryer vent. The problem with this type of unit is it draws air from inside the structure to cool the condenser coils so any time it's cooling air is being drawn in from the outside.
That almost worked.
It's being replaced with a closed loop unit that has almost 2 and a half times more cooling capacity.
I'm thinking a 3/4 ton split, probably not big enough, would work most of the year.
I figured a 1 ton split will likely cool decently on all but the hottest days.
A 1.5 ton should work pretty good.
And a 2 ton removes all doubt.
A 2.5t would just be overkill.
3 ton is just showing off.
